Alphacool unleashes TR4 retention kits and teases a dedicated Threadripper water block
Alphacool releases TR4 retention kits and teases a dedicated TR4 water block
Alphacool has released their new TR4-ready retention kits for their Eisbaer series of CPU AIO liquid coolers, their XPX ice CPU water block and Be Quiet!’s Silent Loop series of AIO liquid coolers. This upgrade kit allows all of these coolers to easily mount onto AMD’s new Threadripper series CPUs, allowing them to cool CPUs with up to 16 cores and 32 threads.
Alongside this Alpahcool has also revealed a prototype of their upcoming Eisblock Flatboy CPU water block, a block that was originally designed for server-grade CPUs and comes with an integrated pump. This block can utilise fluid inputs and outputs on the sides and front of the water block, though on TR4 systems this block’s connection points can interfere with your motherboard’s nearest memory slot.
 Alphacool’s new AMD Threadripper/EPYC CPU mounting kit is now available for €7.95 on the company’s official website.
You can join the discussion on Alphacool’s new TR4 retention kit and Flatboy water block on the OC3D Forums.
