Antec Launches their Silent Guardian Chassis – A Silent Case with 8 HDD Mounts
Antec Launches their Silent Guardian Chassis - A Silent Case with 11 HDD Mounts
In 2019 Antec plans to release their new P101 Silent chassis, a new PC case that will satisfy the needs fo storage purists and silence freaks alike, offering mounting positions for eight 3.5-inch drives while also offering sound deadened side panels to provide minimal noise.
The front of the chassis is mounted upon a hinge, which reveals a 5.25-inch drive bay and removable dust filter that covers three 120mm fans which are installed at the front of the enclosure. At the rear of the case, there is also a single 140mm exhaust. The P101 Silent has no space for fans at the top of the chassis.
The case measures in at 527 mm x 232 mm x 506 mm (L x W x H), offering enough space for ATX, MATX and ITX mainboards, the case providing support for two 2.5-inch drives behind the case’s motherboard tray. Each of this P101 Silent’s 3.5-inch drive bays is mounted in pairs and can be removed is the user wishes, enabling users to mount up to a 360mm radiator at the front of the case.
With the P101 Silent Guardian, Antec is offering a range of standard I/O options, including twin USB 2.0 (White LED lit), 2x USB 3.0 ports (white LED lit), mic/audio in/out ports, power/reset buttons and a fan speed controller with high/low and Stop options.
Antec’s P101 Silent Guardian is now available in the US for $109.99.
You can join the discussion on Antec’s Silent Guardian chassis on the OC3D Forums.
