ASUS reveals their TUF Gaming GT501 chassis
ASUS is set to re-enter the case market with their upcoming TUF Gaming GT501 chassis, offering a rugged, militaristic design with unique carry handles and plenty of space inside for water cooling.
Hardware Canucks got the opportunity to have a sneak peek at the GT501, saying that the case will be available for around $149. Those who want a more in-depth look at the TUB GT501 can have a look at Hardware Canuck’s video below, though note that some of the case’s features are still in development, like a planned vertical GPU mount, a redesigned PSU shroud and other aesthetic tweaks.
Water cooling wise the system can handle two full 360mm radiators, with one on the top and one at the base of the case, with the whole system being movable using two removable fabric handles. These handles are capable of holding the full weight of a system, even if it is water cooled.
Another unique feature of the chassis it is textured metal front and side panels, giving the case an armoured plate aesthetic, fitting in nicely with ASUS’ other TUF-branded products.
You can join the discussion on ASUS’ TUF Gaming GT501 system chassis on the OC3D Forums.
