ASUS showcases their ROG Ryuo IV SLC 360 ARGB CPU liquid cooler at CES 2025
ASUS unveils their ROG Ryuo IV SLC 360 ARGB CPU liquid cooler at CES – The perfect cooler for BTF builds?
At CES 2025, ASUS showed us their new ROG Ryuo IV SLC 360 liquid cooler, which was gorgeous. With its 6.67-inch curved AMOLED display and new CPU block design, this new liquid cooler had “wow” factor. Furthermore, its new tubing routes make this AIO liquid cooler perfect for BTF PC builds.
As you can see below, this new CPU cooler from ASUS uses shorted tubing routed to connect its CPU block to the radiator above. This minimises your PC’s cable/tubing clutter and focuses users on other components. ASUS says that this makes this AIO perfect for new BTF builds. At CES, ASUS revealed their first AMD BTF-series motherboard, the TUF Gaming B850-BTF.
Note that the fans of this new cooling solution feature a new design. These new ASUS RYUO series fans add a “cyberpunk” style aesthetic to your PC build with RGB lighting on its sides and fan blades. Note that these fans are daisy-chainable and use a magnetic connector to link fans together and transmit power and control signals.
The curved 6.67-inch AMOLED screen on the RYUO IV SLC can be used to display hardware information, 3D media, or other custom images. This display snaps into place with magnets and can be attached to ASUS’ pump housing in one of two orientations. This allows users to orient their AIO’s screen optimally for user viewing.
Unfortunately, ASUS could not confirm the release date or pricing of this new AIO on the show floor. We expect to hear more about this new CPU cooling solution soon.
You can join the discussion on ASUS’ ROG Ryuo IV SLC 360 ARGB CPU Liquid Cooler on the OC3D Forums.
