Cooler Master announces their MasterAir MA410M Smart RGB CPU cooler
Cooler Master has launched their new MasterAir MA410M CPU cooler, the company’s first SmartRGB cooler with individually addressable RGB illumination and CPU temperature monitoring that can be used to influence the cooler’s RGB lighting.
The MA410M is a single tower heatsink with dual 120mm fans, using Cooler Master’s Continuous Direct Contact 2.0 (CDC 2.0) technology to compress the CPU cooler’s four heatpipes to offer increases CPU contact surface area and increased thermal conductivity. This feature when combined with Cooler Master’s dual-fan cooling solution and patented X-vents and Air-Guided Armor help to deliver consumers Cooler Master’s best performing single-tower CPU cooler to date.
RGB lighting on the MA410M can be controlled using most RGB motherboards using software like ASUS Aura, MSI Mystic Light, Gigabyte RGB Fusion and ASRock RGB Sync, with individual LED control being offered Cooler Master’s Master Software, though those that want software-free control options can use Cooler Master’s bundled addressable RGB controller.
Please note that the fans included with the MasterAir MA410M do not offer RGB LED functions, with the RGB illumination of this heatsink being controlled directly using four RGB LED strips that are integrated into the heatsink’s Air-Guide Armor cover.
The thermal detection probe that is included in this RGB cooler sits around the heatsink’s base, with Cooler Master offering users the ability to define your system’s lighting colour through your CPYU temperature. When this mode is active, blue lighting means cold and red lighting means hot, quite simple.
Using Cooler Master’s RGB controller users can allow the control to be given to motherboards that support addressable RGB LEDs, set the controller to thermal detection mode, change the speed of specific lighting effects and to select specific RGB controller/lighting modes.
Cooler Master’s MasterAir MA410M Smart RGB CPU cooler is available starting today with an MSRP of £59.99 in the UK and $69.99 in the US.
You can join the discussion on Cooler Master’s new MasterAir MA410M Smart RGB CPU cooler on the OC3D Forums.
