Cooler Master release their MasterBox Lite 5 chassis
The front of the chassis is semi-clear, which will allow LED fans to be visible when used with this chassis, creating a similar effect that is seen in tempered glass-fronted cases.
Like many modern case designs, the Cooler Master MasterBox Lite 5 comes with a PSU shroud, which will allow users to managed their PC’s cables with ease. This chassis will also com with support for dual 3.5″/2.5″ drive bays as well as a single dedicated 2.5″ drive bay.
Water cooling wise, this chassis will support a 120mm radiator at the rear of the case or a 240mm/280mm radiator at the front of the chassis.
This new chassis will cost £44.99 in the UK and will be available at retailers before at the end of May.
You can join the discussion on Cooler Master’s MasterBox Lite 5 chassis on the OC3D Forums.
