Cooler Master releases its Mirror Series of Liquid Coolers
Cooler Master releases its MasterLiquid ML Mirror Series of Liquid Coolers
Cooler Master has officially launched their new Mirror series of ML Liquid Coolers, offering users new pump-based RGB lighting effects and radiator sizes which include 240mm, 280mm and 360mm options.
New to the ML240, ML280 and ML360 Mirror AIO Liquid Coolers are their new Mirror Addressable-RGB Lighting pumps, which offer users an “infinite mirror” effect when the pump’s addressable RGB ring is illuminated. This pump features eight addressable RGB LEDs, which users can control through Cooler Master’s lighting controllers and software.
MasterLiquid ML Mirror series products utilise Cooler Master’s 3rd Generation Dual-Chamber pump design, which is designed to ensure that hot and cool coolant remains in separate pump chambers. This design is said to enhance the cooling efficiency of Cooler Master’s AIO liquid coolers. An enhanced pump design also allows Cooler Master’s latest liquid coolers to provide users with quieter noise levels during operation and increased coolant pumping performance.
With these new AIO designs, Cooler Master has also made changes to their radiators and fans, utilising a new radiator which features a 16% increase in liquid passage space to increase coolant flow and an increased surface area to enhance heat dissipation. Cooler Master is also using their SickleFlow 120/140mm fans with these new MasterLiquid Coolers, which feature a new blade design to offer more static pressure to enhance cooling performance.
When informing us about these new AIOs, Cooler Master confirmed that these new units would be “Amazon Exclusive“, with retail listings confirming that MasterLiquid ML240, Mirror MasterLiquid ML280 Mirror, and MasterLiquid ML360 Mirror will cost £99.90, £119.90 and £139.90 respectively in the UK.
When compared to their older AIO offerings, Cooler Master’s new MasterLiquid ML Mirror designs have been created with ease of installation in mind, offering users all the brackets and wires they need to enable all of the functions of the liquid cooler.
While Cooler Master’s MasterLiquid ML Series supports ARGB lighting through most RGB compatible motherboards, such as ASUS, MSI and ASRock, Cooler Master also ships their ML Mirror series coolers with a wired ARGB controller. This controller will allow users to enable full RGB software control through Cooler Master’s software.
You can join the discussion on Cooler Master’s new MasterLiquid ML Mirror series Liquid Coolers on the OC3D Forums.
