Cooler Master shows HUGE 2000W liquid cooler with four 180mm fans
Big radiator, big fans – Cooler Master unveils 2000W liquid cooling solution
Cooler Master is ready to cool the most powerful PCs with a colossal 2000W liquid cooling solution. Their new 360 x 360 “Hyper Radiator” is designed to take up the entire right side of large gaming PCs and workstations, using four 180mm fans for cooling. In terms of surface area, this radiator is equivalent to three standard 360mm liquid cooling solutions.
(OC3D visits Cooler Master HQ during Computex)
This is “Project AIO”, and Cooler Master was showcasing it in several systems at their HQ. With its large fan sizes and huge radiator volume, this cooling solution can dissipate a lot of heat, and do so quietly. Cooler Master claims that this radiator setup can handle 2000W thermal loads, which is overkill for all modern CPU setups.
The Cooler Master version shown to us is intended for high-end workstations and was used with an AMD Threadripper- or Intel Xeon-compatible CPU block. However, we also spotted the radiator inside a Cosmos series PC case. This implies that a consumer-oriented version of this cooler could be in the works.
If nothing else, this cooler has the capacity needed to cool even the hottest CPUs without making much noise. Even high-end AMD Threadripper and Xeon CPUs should be coolable with this unit without needing excessive fan speeds. Sadly, Cooler Master has not unveiled the release date of this cooling solution. Furthermore, they did not discuss a potential consumer version of the product.
You can join the discussion on Cooler Master’s massive 360 x 360 liquid cooler on the OC3D Forums.
