Cooler Master’s MasterBox TD500 Mesh may be the next sub-$100 airflow champion – CES 2020
CoolerMaster's MasterBox TD500 Mesh may be the next sub-$100 airflow champion
This month, Cooler Master plans to release its MasterBox TD500 Mesh, a new airflow-focused case design which aims to keep your system cool under load thanks to the enclosure’s three integrated ARGB (Addressable RGB) fans.
Cooler Master’s TD500 will release with both black and white variants, both of which utilise Cooler Master’s new polygonal mesh to enable high airflow and dust filtration while contributing towards the case’s strengthened structure.
In their press release, Cooler Master has given both versions of the TD500 an MSRP of $89 in the US, offering users a unique Tempered Glass panel which features a “crystalline” structure that allows certain sections of the panel to interact with case lighting.
The TB500 is a full-sized ATX chassis which supports up to three 120mm fans in the roof and three 120mm fans in the front. This gives the case ample room for water cooling components. Storage-wise, the case features four dedicated mounts for 2.5-inch drives and space for two 3.5-inch/2.5-inch drives under the case’s PSU shroud. This allows the TD500 Mesh to support up to six storage drives.
You can join the discussion on Cooler Master’s Masterbox TD500 Mesh enclosure on the OC3D Forums.
