Corsair’s H115i PRO and H150i PRO coolers have leaked
Corsair's H115i PRO and H150i PRO coolers have been leaked
Corsair is set to release their next generation of all-in-one (AIO) liquid coolers, offering new pump and radiator designs to increase the performance of their units while also reducing noise output.
This new series of pre-filled liquid coolers will launch under the Corsair PRO brand, offering RGB illumination on the device’s CPU block and make use of Corsair’s new ML-series (Magnetic Levitation) fan technology to deliver minimal fan noise under load. Corsair’s PRO series of AIOs will be the company’s quietest cooler to date.
Back at Computex, Corsair confirmed that they were working on a 360mm AIO liquid cooler. We now know that this new AIO liquid cooler will be called the H150i PRO, which will offer “link compatible” RGB illumination and three ML120 series fans. Below we have a picture of Corsair’s upcoming H115i PRO, which is a 280mm AIO liquid cooler which features the same pump design and comes with two ML140 series fans.
Corsair has not officially confirmed when both of these AIO liquid coolers will release, though Corsair’s PRO series is also expected to release with 240mm and 120mm variants.
Recent rumours have also stated that Corsair has been working on a “Silent Start Mode” and “Zero RPM” fan mode for their AIO liquid coolers, which are designed to minimise the noise produced by the unit on startup and deliver silent operation while your system is idling.
Corsair's H115i PRO and H150i PRO coolers have been leaked  Corsair's H115i PRO and H150i PRO coolers have been leaked
You can join the discussion on Corsair’s upcoming H115i Pro and H150i PRO AIO liquid coolers on the OC3D Forums.
