EK showcases a “Concept Case” at CES 2021
EK has designed this concept case with modularity in mind, allowing users to add custom parts or alter their chassis in whatever way they see fit. EK has also designed this enclosure with a VESA mounting solution to make the case mountable on walls, monitor-style mounts and other custom solutions.
Below, you can see this enclosure pictured with ASUS’ Z590 Maximus XIII Extreme Glacial (which was designed in collaboration with EK) and a graphics card with EK’s Active Backplate Cooling solution.
At this time, EK has not revealed any plans to bring this concept case to market.
This is an open frame modular case that supports adding an extra radiator mount and can be the perfect display solution for your liquid-cooled PC. It offers a standardized VESA mount on its backside, meaning that you can hook it up on the wall or even use regular TV or monitor arm-style mount to move it around. The case design also supports a unique mounting system on the bottom that allows the user to mount it to the backside of the desk. Of course, while using it on a wall mount, this part can be removed.
You can join the discussion on EK’s “Concept Case” on the OC3D Forums.
