EK is releasing Intel SSD 750 Series water block
EK Water Blocks, Ljubljana based premium liquid cooling gear manufacturer, is proud to introduce its first solid-state drive water block – the EK-FC I750 SSD for Intel Solid-State Drive 750 Series!
EK is releasing Intel SSD 750 Series water block  EK is releasing Intel SSD 750 Series water block
EK-FC I750 SSD is a Full-Cover water block for water cooling the Intel SSD 750 Series solid-state drive. Designed in cooperation with Intel®, we followed the overall look of the original passive cooler and made sure the entire PCB is covered, thus delivering the best possible cooling performance.
The water block features a high flow design allowing it to be easily used with systems using weaker water pumps. The base is made of nickel-plated electrolytic copper while the top cover is made of stainless steel. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure.
Enclosed is the additional EK-FC Terminal with two G1/4″ threaded ports on the side (right picture above). Customers might need it if there isn’t enough space to install the fittings on a regular pre-installed terminal (left picture above).
EK-FC I750 SSD is readily available for purchase through EK Webshop and Partner Reseller Network. MSRP price with included VAT is in the table below.
You can see OC3D’s review for Intel’s SSD 750 NVMe SSD here.
You can join the discussion on EKWB’s full cover water block for Intel’s SSD 750 on the OC3D Forums.
Want to water cool your Ultra fast NVMe SSD? Well EK has you covered with their Intel SSD 750 series water…
Posted by OC3D on Monday, 12 October 2015
