EVGA reveals ROBOCLOCKER LN2 AIO Liquid cooler
Vince “KINGPIN” Lucido and Illya “TiN” Tsemenko, professional overclockers who work at EVGA’s Taiwan office, decided that they were “sick of pouring” and embarked on a journey which would modernise the LN2 liquid cooling scene. Most PC builders have seen a closed loop/all-in-one liquid cooler, but what if that concept could be applied to LN2.
This idea eventually lead EVGA’s hardware teams alongside KINGPIN and TiN to create what is now known as the EVGA Roboclocker, an automated LN2 semi-closed loop liquid cooler which takes a lot of the pain out of extreme overclocking.
The benefits of EVGA’s Roboclocker are twofold. First, the system saves a lot of liquid nitrogen, with waste Nitrogen gas collecting in a secondary tank while the system itself minimises the LN2 requirements of extreme overclocking. This increase in LN2 efficiency allows large LN2 tanks to be used for longer without expensive refills while also allowing Nitrogen gas to be collected after use, rather than let it dissipate into the atmosphere.
The second benefit is that the system can increase LN2 throughput based on temperature changes and current changes, allowing for more LN2 to be released into the system while benchmarks are running, allowing users to focus on system adjustments and benchmarking, rather than maintaining an ideal system temperature.
EVGA’s Roboclocker has been in use for the past few months, with the system having already achieved several world record overclocks. The system shown below could be used to control the temperatures of a single CPU and up to four GPUs simultaneously, with system parameters being adjustable using a laptop that is connected wirelessly to the control unit.
While this isn’t a consumer-grade product, it showcases EVGA’s willingness to support the extreme overclocking crowd and that deep down the company is full of PC enthusiasts at heart. The Roboclocker isn’t a product that will earn the company any money, though the world records that it will help achieve may help the company gain a higher standing amongst some overclockers.
You can join the discussion on EVGA’s Roboclocker LN2 AIO liquid cooler on the OC3D Forums.
