Here’s what HAVN had to show us at Gamescom 2025
Let’s have a look at HAVN’s booth at Gamescom 2025
We’ve been lucky enough to have a look at the HAVN Booth at Gamescom 2025, where we got to see the company’s latest products. HAVN is a relative newcomer to the PC market, though that has not stopped the company from making a splash.
We reviewed HAVN’s HS 420 PC case last year, and it is a phenomenal case. With that as their debut product, we are excited to see what the company has coming next. Thankfully, HAVN did have something new to show us, and it will be releasing soon.
(Steven Levitt shows us the goods!)
HAVN HS 420
We’ve already reviewed the HAVN HS 420, but that doesn’t mean that we can’t admire the company’s PC building efforts. Below, we have the standard HS420. Thanks to its re-oriented PSU mounts, this case can have up to three bottom-mounted fans for airflow, despite the fact that this is a single-chambered case. This case has plenty of options for airflow, supporting eleven fans in total.
The HS 420 also has a “VGPU” version, which ships with a vertical GPU mount, a PCIe 5.0 riser card, and a custom fan bracket that pushes air towards the front of your graphics card. This creates an ideal airflow situation for vertically mounted GPUs, assuming they are air-cooled.
HAVN showcased its next case at Gamescom 2025 – Meet the HAVN BF 360
At Gamescom, HAVN showcased several PC builds using its new BF 360 chassis. We saw this case at Computex 2025, and HAVN has confirmed that this case will be released soon. While we can’t give you a specific date, we can tell you that you won’t have to wait for long.
This case will be available with and without fans. The “fans included” model will come with two 180mm fans and one 140mm fan. The two 180mm fans will act as front intakes, pushing a lot of cool air into the system. At the top of the case, users have the option to mount two more 180mm fans. Alternatively, users can mount a 360mm liquid cooler at the top of this case.
Sadly, we have not been told the pricing of HAVN’s new BF 360 PC case, though we know that more information will be revealed soon. When this case launches, it will be available through Caseking and Overclockers UK.
You can join the discussion on HAVN’s presence at Gamescom 2025 on the OC3D Forums.
