Lian Li launches their new Lancool 207 PC case
Lian Li’s new Lancool 207 looks like it could be a great budget gaming case
Lian Li’s new Lancool 207 PC case will soon be available to PC builders. This was one of our favourite cases that Lian Li showcased at Computex 2024, where Lian Li stated that the case would launch for $79.99 and ship with four fans.
What’s unique about this PC case is how its base is oriented. Its power supply is moved to the front of the enclosure, and 120mm fans are placed at the base of the case for added airflow. This directs cool air directly at your graphics card, making the 207 a gaming-oriented chassis. Note that the new images of this case don’t include the reverse-blade fans that this case was showcased with at Computex.
(Image from Techpowerup)
This case will be available in black and white and supports motherboards up to ATX in size. The case features a tempered glass side panel, and features two ARGB illuminated 140mm fans at the front of the case. Note that this case includes no exhaust fans out of the box.
At the top of the 207 are mounts for up to 280mm or 360mm liquid cooling radiators. That’s enough space for most modern CPU liquid cooling solutions.
GPU-wise, this case supports cards up to 375mm in length. This is large enough to accommodate all but the largest graphics cards. Not bad for such an affordable PC case. Since this case is expected to cost $79.99, we expect this case to prove popular among budget-oriented PC enthusiasts. After all, not many cases of this price point ship with four fans.
You can join the discussion on Lian Li’s new Lancool 207 PC case on the OC3D Forums.
