Lian Li DK-05 desk/chassis hybrid has been officially released
This desk will also release with full height adjustability, with motorised adjustment from 69cm to 118cm in height. In terms of desk space, this colossus offers a 140cm x 78cm or real estate, which is more than enough for a large multi-monitor setup.
For both systems inside this case/desk, there will be front facing VR-ready HDMI ports, a USB 3.1 Type-C header and dual USB 3.0 ports, with dedicated power and dials to adjust the case’s RGB illumination. On the right-hand side of the chassis, there will also be a single 5.25-inch drive bay for use with optical media.
Inside this chassis, there will be enough room for a single 420mm radiator and three 360mm radiators, allowing both systems inside to be liquid cooled with ease. The chassis will also come with three mounts for pumps and enough space for 4x 3.5-inch drive bays and dual 2.5-inch drive bays per system.
The key specifications of the Lian Li DK-05 are listed below:
- – Motorised height adjustable desk from 69cm to 118cm
- – 140cm x 78cm tempered glass desk top
- – Full Aluminium body, with iron legs
- – Includes 12x 120mm fans
- – Fits graphics cards up to 360mm in length
- – USB 3.1 Type-C and HDMI on front panel
- – Fits up to two Extended ATX motherboards
- – Houses 8x shared 2.5-inch/3.5-inch and 5x 2.5-inch drives
Lian Li’s DK-05 desk/chassis hybrid is now available at Overclockers UK for £1999.99.
You can join the discussion on Lian Li’s new DK-05 desk/chassis hybrid on the OC3D Forums.
