Noctua releases a trio of coolers for Ryzen Threadripper and EPYC
Noctua’s SecuFirm2 mounting systems have become synonymous with quality, safety and ease of use. The TR4-SP3 variant has been completely custom-designed for the new socket and is particularly easy to install: Put on the heatsink, fix the four spring-loaded screws and you’re done!Please note that the NH-U14S TR4-SP3 is a dedicated version for the AMD TR4/SP3 socket. Due to its customised larger base, it cannot be used on any other sockets and is incompatible with Noctua’s standard mounting kits.
One key feature of Noctua’s new cooler design is the ability to move this cooler 3 or 6mm higher than each cooler’s standard mounting configurations, which will allow users to move these coolers to offer improved compatibility with certain PCIe devices on standard motherboards.
In order to assure optimal compatibility with SLI and CrossFire multi-GPU setups, the SecuFirm2 mounting for TR4/SP3 makes it possible to offset the cooler by 3 or 6mm towards the upper edge of the motherboard, thereby increasing clearance of the top PCIe slot.
All of these coolers will come with a 6-year warranty and can be used in push/pull configurations if required.
All three cooler models will be shipping shortly and should start to appear in stores by the end of August. The suggested retail prices are as follows:
– NH-U14S TR4-SP3: EUR 79.90 / USD 79.90
– NH-U12S TR4-SP3: EUR 69.90 / USD 69.90
– NH-U9 TR4-SP3: EUR 69.90 / USD 69.90
You can join the discussion on Noctua’s TR4/SP3 cooling lineup on the OC3D Forums.
