NXZT expands their H-series with H500 and H500i cases
Thankfully NZXT has answered the calls of consumers with non-i variants of their H700i, H400i, and H200i enclosures, though there remained a gap in the market for customers that wanted a full ATX chassis but didn’t want a case as large as the gargantuan H700i. NZXT needed a product in their new H-series that could fill the role of their fan-favourite S340 chassis.
This niche is where the new H500 and H500i come in, offering support for full ATX motherboards in a compact overall form factor and a price tag of $69.99 and $99.99 respectively. The H500i will provide users with an integrated NZXT smart hub, which includes a HUE and GRID functionality to control up to three fan channels, up to four HUE LED strips or 5 Aer RGB fans and a built-in noise sensor for Adaptive Noise Reduction. Otherwise, both cases are identical, using the same tempered glass side panels and internal layout. The H500i also ships with a vertical GPU mounting bracket and two pre-installed RGB strips.
When compared to its other H-series brethren, the H500 only supports a single 240/280mm radiator at the front and a 120mm radiator in the rear, lacking the top-mounted radiator support of the more expensive H700, H400 and H200 series. Fan-wise the chassis supports 2x 120/140mm fans in the front, a single 120/140mm fan at the top and one 120mm fan in the rear.
On the case’s front I/O there are two USB 3.1 Gen 1 (USB 3.0) connections and audio input/output jacks. The chassis will also ship in all-black, white/black, red/black and blue/black.
NZXT’s new H500 and H500i cases will be available in early June in the US and Mid-June in the EU and the rest of the world with a retail price of $69.99 and $99.99 respectively. This pricing makes the H500 series the most affordable entry point into NZXT’s new H-series of PC cases.
You can join the discussion on NZXT’s new H500 and H500i series of PC cases on the OC3D Forums.
