NZXT released Limited Edition PUBG Licensed H700 case
NZXT released Limited Edition PUBG Liscensed H700 case
In collaboration with both PUBG Corp and Gamers Outreach, NZXT has designed and manufactured a Limited Edition H700 chassis a design aesthetic that is similar to PlayerUnknown’s Battlegrounds airdrop crates.
Internally this chassis is the same as any other H700 enclosure, providing the same all-steel construction with a tempered glass-windowed side panel, impressive cable management options and a myriad of water cooling options. 10% off all purchases will be donated to Gamers Outreach, a charity which focuses on providing equipment and software to help children cope with treatment inside hospitals.
The production of this chassis will be limited to 2,000 units, each of which will be numbered, with each case costing $199.99 each, making NZXT’s maximum donation to $40,000 if the case cost is rounded to $200 and every PUBG licensed chassis is sold.
The main difference between NZXT’s H700 PUBG and their existing H700i chassis (aside from aesthetics) is the case’s lack of an integrated “smart device”, which offers integrated support for three 10W fan channels and the ability to control four HUE LED strips or five Aer RGB series fans. This lack of smart functionality is why NZXT’s limited edition H700 PUBG chassis costs the same as the company’s standard H700i enclosure.
NZXT’s limited edition H700 PUBG-themed case is available exclusively in the US for $199.99.
You can join the discussion on NZXT’s Limited Edition PUBG Licensed H700 chassis on the OC3D Forums.
