NZXT Manta Mini-ITX Water cooling case
NZXT has just released their new Manta ITX chassis, which features a new curved design, an expansive interior and extensive water cooling support that allows for push pull radiators on the top and front.
The new case offers support for NZXT’s Kraken X61 280mm radiator which can be supported in even a push pull fan configuration, promising very cool temperatures through the magic of water cooling.
NZXT Manta Mini-ITX Water cooling case  NZXT Manta Mini-ITX Water cooling case
This case is using a whole new manufacturing technology from NZXT, offering an all new curved design which is certainly eye catching.
FEATURES
– New manufacturing technology offers unparalleled build quality
– Elegant, curved steel paneling and window
– Double the cable management space
– Dual 280mm liquid cooling support
– Kraken X61-ready with push/pull capabilities
– Integrated PSU shroud for a beautifully clean build
– Fully filtered, easy-to-remove intake
SPECIFICATION
– Dimensions: W: 245mm x H: 426mm x D: 450mm
– Material(s): Fully steel plated exterior, steel chassis
– Total Weight: 7.2kg
– Motherboard Support: Mini-ITX
– External Features: 2xUSB 3.0, 1x Audio/Mic, I/O Panel LED On/Off
– Internal 3.5”: 2
– Internal 2.5”: 3
– PCI Expansion Slots: 2
– Cooling: Front – 2x 140mm/120mm (2x120mm included), Top – 2 x 140mm/120mm, Rear – 1 x 120mm (included)
– CPU Cooler Clearance: 160mm
– GPU Clearance: 363mm
– PSU Length: 363mm
– Packaging Dimensions (WxHxD): 295 x 495 x 470mm
– Gross Weight 8.6kg
– Model: CA-MANTW-W1
Right now NZXT’s new Manta Mini-ITX chassis is priced at £109.99 at Overclockers UK.
You can join the discussion on NZXT’s new Manta Mini-ITX Case on the OC3D Forums.
