Phanteks Announces Enthoo Mini XL Dual System Chassis
Phanteks Announces Enthoo Mini XL Chassis
With the overwhelming response from the community, users have requested for a solution to the Enthoo Mini XL’s dual system configuration setup. Today, Phanteks announces the release of the Enthoo Mini XL Dual System. The Mini XL Dual System will have Phanteks Power Splitter and the Mini ITX upgrade kit pre -installed. With Enthoo Mini XL Dual System, users can run two fully functional system independently of one another. The Mini XL Dual System provides users to have the option of having a high powered gaming system and workstation or Gaming system and streaming system all in one case.
The Mini XL Dual System, a compact and power structure with sandblasted aluminum faceplates with matte finish. The Mini XL has a stealthy interior design with hidden PSU and HDD’s. It also comes with two separate front I/O for the dual systems and a light system with multi-color control (10 colors). The Mini XL Dual System will feature dual removable hard drive cages, 2x Drop-N-Lock SSD brackets, fully equipped dust filters, mod friendly structure, and Phanteks’ cable binders for easy cable management.
Phanteks Announces Enthoo Mini XL Chassis  Phanteks Announces Enthoo Mini XL Chassis  Phanteks Announces Enthoo Mini XL Chassis
The Mini XL Dual System comes with a convenient pump bracket, PWM control hub, and a radiator bracket. The case is equipped with 3x Premium Phanteks’ fans for optimal airflow to the CPU and GPU. Also, the power supply’s location will be isolated from the other components.
The Mini XL Dual System will allow two sytems to run independent of one another. The Dual System will include the pre-installed ITX upgrade kit and Power Splitter. With the Power Splitter, two motherboards can now be power up using only one power supply. The ITX upgrade kit will also be pre-mounted and ready for your dual system configuration.
Available from December 2015, the Enthoo Mini XL Dual System Chassis is expected to be priced at 209.90€ or £159.99 (including taxes).
My thoughts
With the case set up from the start with a built in PSU Power splitter and a enough space to accommodate a mini ITX and a micro ATX motherboard building a dual system PC has never been quite this easy.
One thing that needs to be remembered however is that the PSU in such a dual system better be able to power two full systems under load, and you better have a fan setup that is ready to prevent any thermal build up.
You can join the discussion on the Phanteks Enthoo Mini XL System Chassis on the OC3D Forums.
