Razer reveals its Tomahawk Mini-ITX and ATX PC Gaming Enclosures
Razor has officially revealed their first “true” desktop enclosures, the Tomahawk ATX and Tomahawk ITX, both of which are designed for gaming enthusiasts and “engineered with airflow in mind”.
Both of these enclosures are designed with two tempered glass windows to allow PC builders to showcase their desktop components, and features a robust cable management solution which will allow PC builders to create tidy systems with ease.
Both the ITX and ATX models feature an all-black front panel, which features a green illuminated Razer logo. In addition to this, these enclosures also feature Razer Chroma RGB lighting at its base, which can be customised using Razer’s Synapse 3 software.
In the UK, Razer’s Tomahawk ATX will retail for £199.99, while the company’s Tomahawk ITX will ship for £179.99. Both models are made using 0.8mm thick SPCC steel and feature two tempered glass side panels.
The Tomahawk ATX will feature support for up to a 360mm radiator at the front of the enclosure, while the ITX model will support up to a 240mm radiator at the top of the chassis.
Both models will feature support for dual USB 3.2 Gen 2 Type-A ports at the top of the chassis as well as a single USB 3.2 Gen 2 Type-C port. RTazer has also given both models a 1-year warranty. The full specifications of both enclosures are available in the table below.
You can join the discussion on Razer’s Tomahawk ITX and ATX PC cases on the OC3D Forums.
