Thermaltake reveals their Tower 100 Mini-ITX enclosure for powerhouse PCs
Thermaltake wanted to take the iconic Tower 900 chassis and scale it down for more compact PC builds, allowing their fans to create mini powerhouse PCs that offers the same visual impact as their larger counterparts. Meet the Tower 100, Thermaltake’s first new case of CES 2021.
The Tower 100 was designed with airflow in mind, with filtered ventilation at the top and bottom of the enclosure and three tempered glass side panels to allow users to see their components from all angles.
In the UK, the Tower 100 will be available with sub-£100 price points and with black/white colour options. The case will supports graphics cards that are up to 330mm long and CPU coolers that are up to 190mm in height. ATX power supplies up to 180mm long are also supported
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, announces the launch of the brand-new, The Tower 100 Mini Chassis at the 2021 Thermaltake Expo January Virtual Exhibition. Based on the award-winning The Tower 900, “Pocket-sized” down into a mini-ITX form factor powerhouse, The Tower 100 takes on compact cooling and showcases your build with the perfect presentation.
The case comes with two preinstalled 120mm standard fans on top and at the rear for thermal extraction. Moreover, you can put one extra 120mm or 140mm fan on the top of the PSU cover and a 120mm All-in-One CPU cooler can be fitted on the top for basic watercooling. The Tower 100 supports two 2.5-inch SSDs with the case’s side bracket, and two 2.5/3.5-inch HDD at the rear of the enclosure (without rear fan).
Featuring support for large graphic card solutions up to 330mm in length, The Tower 100 supports filtered ventilation from top to bottom. Combine the beauty of 4mm thick tempered glass with ventilated steel side panels provides balance of show and flow. From the foundation, The Tower 100 is opened up for more airflow to the top panels easy push button cover to provide easy access to connect up your components. Angled top mounted I/O panel supporting USB 3.2 (Gen2) Type-C with USB 3.0 ports and HD audio for easy connectivity.
With airflow in mind, cable management is also covered throughout The Tower 100 with a custom cover plate. Modular cut out for larger graphic cards, supporting native “No Sag” vertical mounting, provides a convenient way to hide your GPU cables and easily connect to your power supply located at the back of the case. The large grommet provides access for your I/O and cable connections with a modular honeycomb designed back plate that doubles as storage mounting or more airflow thanks to the rear 120/140mm fan option located on the back panel. Straight forward, All-In-One cooling supports 120mm radiator solutions with an additional 120/140mm fan location above the PSU cover and CPU coolers up to 190mm in height.
Providing a modular design, with enthusiast in mind, easily remove panels for customization or proper maintenance. Mod on with your build to create one-of-a-kind designs and take advantage of easier installation by removing panels from the frame. Removable dust filters make it easy to clean or be removed completely for maximum airflow. Gain more storage with HDD/SSD mounting on the interior side and back panel to lock and load all your favorite media and games.
When it comes to front IO, Thermaltake’s Tower 100 supports dual USB 3.0 connections as well as a single USB 3.1 Gen 2 Type-C port on its top panel. The case also features audio in/out ports as well as standard power/reset buttons.
Thermaltake has designed their Tower 100 with DMD in mind, with DMD standing for “Dismantlable Modular Design”. Tower 100 users can take their chassis apart with ease, making the enclosure a modder’s paradise. Want to recolour a panel? Take it off and start painting! Need access to a hard to reach place? Take off some panels and get easy access. The Tower 100 is designed to take the challenge out of PC building, and give moders a lot to tinker with.
Strip your case down to the bones and install elements when and as you need them with our modular design. The Tower 100 features modular panels, racks, brackets, and pre-designed mounting arrays. No more unreachable screw corners or gaps, installation can be a breeze with our Dismantlable Modular Design.
Thermaltake’s Tower 100 chassis will be available soon worldwide in both white and black.
You can join the discussion on Thermaltake’s Tower 100 Mini-ITX chassis on the OC3D Forums.
