Thermaltake Release The Lanbox Lite
News Posted 02/04/07
Author: PV5150
Source: Thermaltake
Official Press Release
The mirror-finish found on LANBOX Lite exhibits extraordinary elegance along with steel meshed front bezel design for greater thermal performance. In addition, the LANBOX Lite inherits LANBOX spirit. Unlike tower chassis, small form factor PC often lacks sufficient cooling capability or expandability to allow enthusiasts to build a capable gaming machine.
Designed from the ground up, LANBOX Lite is a fully modular chassis where all components may be removed from the body for easier installation. Everything from Motherboard Tray to 5.25” Bay Drive cage can be easily removed with a twist of the thumb screws. Thermal engineering played an equally important part when designing the LANBOX Lite.
Today’s most high-end graphic cards or processor often requires added cooling and high-wattage power supply in order to operate at their maximum capability. Before, gaming enthusiasts that opted to build a small form factor PC were limited to mid-end graphic card or processor that resulted in mediocre performance.
Today, LANBOX Lite enables the use of standard Micro ATX motherboard, most high-end CPU, powerful graphic card and even a standard full-size PSU; the result, a small form factor PC that is equally powerful as full sized PC. LANBOX Lit is the ultimate chassis solution for your high-efficiency small form factor PC.
Read more on the Lanbox Lite here
Discuss in our forum
