AMD releases their Ryzen Threadripper 1900X CPU
In terms of pure CPU clock speed, AMD’s Threadripper 1900X offers a boost over AMD’s AM4 R7 1800X, offering base clock speeds of 3.8GHz and a maximum XFR boost of 4.2GHz, giving the 1900X more single-threaded CPU performance in addition to its support for 4-channel memory and additional PCIe lanes.
When compared to similarly priced Intel CPUs, the 1900X offers insane levels of PCIe connectivity, making it the perfect CPU for those that desire a system with multiple PCIe devices and NVMe SSD RAID (NVMe RAID will be enabled with BIOS and driver updates on September 25th).
This CPU will be built using a (4+0)+(4+0) CPU core configuration, which means that on the two active Ryzen CPU dies on this CPU, only four are active on each CPU, all of which are from the same CCX unit. This will minimise inter-core latency within the same CPU die.
The Ryzen Threadripper 1900X is a CPU for those that care more about PCIe connectivity than pure CPU performance, offering the same number of PCIe 3.0 lanes as AMD’s more expensive 1920X and 1960X CPUs while still offering a reasonable core/thread count.
Below are a few examples of what can be done using Threadripper’s 64 PCIe lanes. Also note that Threadripper does support ECC DDR4 memory, though users will need to ensure that they purchase an ECC compatible motherboard to make use of this error-correcting memory type.
AMD’s Threadripper 1900X is a very interesting product that is exceptionally useful for certain workloads, offering support for ECC memory on compatible motherboards and support for more PCIe devices that Intel’s competing X299 offerings.
You can join the discussion on AMD’s Ryzen Threadripper 1900X CPU on the OC3D Forums.
