AMD Ryzen “Spire” and “Wraith max” coolers leak
AMD Ryzen
Some new leaks have emerged which have detailed AMD’s new “Wraith Max” and Ryzen “Spire” stock coolers, which promise to give AMD’s Ryzen CPUs an enhanced “stock cooling” experience.
AMD’s new “Wraith Max” cooler comes with a max thermal design power of 140W, which will allow the cooler to handle AMD’s 95W Ryzen flagship with relative ease and without the need for an overly loud operation under load. This new cooler will be a refined version of AMD’s original Wraith cooler design, which shipped with select AMD FX-series CPUs.
The Wraith Max is said to ship with AMD’s Ryzen 7 1800X and 1700X CPUs, with lower-end models shipping with AMD’s new Ryzen “Spire” CPU cooler design, which looks very similar to the basic design of Intel’s stock cooler. The Spire cooler is listed with a TDP of 95W, making it suitable for all of AMD’s Ryzen lineup, but unsuitable for AMD’s XFR (eXtended Frequency Range) technology and any form of overclocking.
AMD Ryzen
While most PC enthusiasts will likely to continue to use aftermarket cooling solutions, it is great to see AMD moving to use new cooler designs that are not only quieter than their predecessors but may actually worth using on budget, non-overclocked PC builds.
You can join the discussion on AMD’s Ryzen CPU stock cooler designs on the OC3D Forums.
