AMD showcases Ryzen 7 1700 running with 3400MHz memory
Please note that this testing was conducted on AMD’s Ryzen 7 1700, which is AMD’s lowest Ryzen SKU at the time of launch, which should mean that all Ryzen CPUs are capable of running fast DDR4 memory speeds with the correct motherboards and new BIOS revisions.
Below is a CPU-Z screenshot showcasing the memory speeds of AMD’s new Ryzen 7 CPU.
When we review AMD’s Ryzen CPUs we will be having a deep look at memory clock speeds and exactly what each of our CPU samples are capable of. Will we be able to exceed 3400MHz?
You can join the discussion on AMD’s Ryzen CPUs running 3400MHz memory on the OC3D Forums.
