EK release their Gigabyte compatible Z270X RGB Monoblock
EK has released their new Gigabyte compatible Z270X RGB Monoblock, which supports nine different motherboards and supports RGB Fusion technology.
This monoblock design is not only more aesthetically pleasing than most multi-block offerings but it also simplifies hose/tubing management, with only a single input and output holes for coolant instead of the having to deal with inputs and outputs for several separate motherboard and CPU water blocks.
Below is a list of motherboards that are compatible with EK’s new Z270X RGB Monoblock.
- GA-Z270X-Gaming 7
- GA-Z270X-Gaming K7
- GA-Z270X-Gaming 5
- GA-Z270X-Gaming K5
- GA-Z270X-Ultra Gaming
- GA-Z270-Phoenix Gaming
- GA-Z270-Gaming 3
- GA-Z270-Gaming K3
- GA-Z270X-UD5
This new waterblock is currently available for Pre-order on the EK webstore for €117.98, offering support for RGB lighting through use of a 4-pin RGB LED header.
You can join the discussion on EK’s GA Z270X RGB motherboard on the OC3D Forums.
