Gigabyte unleashes their Mini ITX GA-AB350N Gaming WiFi Rzyen motherboard
Gigabyte unleashes their first Ryzen Mini ITX motherboard
Gigabyte unleashes their first Ryzen Mini-ITX motherboard
Gigabyte has revealed their first Ryzen mini ITX motherboard, the GA-AB350N Gaming WiFi, which comes with overclocking support through AMD’s B350 chipset and includes WiFi support through the use of an 802.11ac WiFi card.
This motherboard comes with support for Ryzen CPUs, 7th generation Bristol Ridge APUs and AMD’s upcoming Ryzen-based Raven Ridge APUs. We can see that this board features a 6-phase VRM design and offers 4 SATA 6Gbps connections and a single 32 Gbps M.2 slot on the rear of the motherboard.
The GA-AB350N Gaming WiFi will sport four USB 3.0 ports on the rear IO alongside dual USB 3.1 ports, with HDMI and DisplayPort outputs which will be usable with AM4 APUs.
Just like most MITX motherboards, the GA-AB350 Gaming is restricted to dual slot DDR4 memory and a single PCIe 3.0 output, which isn’t really a restriction of the motherboard but a restriction of the MITX form factor.
Gigabyte has not released the pricing or availability information about this motherboard, though we can expect to see this board hit store shelves relatively soon.
You can join the discussion on Gigabyte’s GA-AB350 Gaming WiFi AM4 motherboard on the OC3D Forums.
