Alleged RTX 3070 Ti and RTX 3070 specifications surface – More CUDA cores!
These new consoles will make former PC exclusive features like Variable Rate Shading and Ray Tracing commonplace amongst multi-platform games, changing what should be expected from graphics cards in the PC space.
Nvidia’s answer to these new consoles is there RTX 30 series of graphics cards, a series which will utilise the company’s refined Ampere graphic architecture and deliver a major performance leap over Turing. Today, alleged specifications for Nvidia’s RTX 3070 Ti (or Super) and Nvidia’s RTX 3070, both of which offer gamers more CUDA cores than their Turing-based counterparts.
Nvidia’s alleged RTX 3070 Ti design has been listed as having 3072 CUDA cores by the leaker kopite7kimi, who has also listed Nvidia’s RTX 3070 as having 2904 CUDA cores. These core designs give Nvidia’s rumoured Ti/Super design a 5.7% increase in total CUDA cores, though factors like memory speed could further differentiate these units.
In terms of CUDA core count, Nvidia’s RTX 3070 Ti is identical to Nvidia’s RTX 2080 Super, while Nvidia’s RTX 3070 is the same as Nvidia’s standard RTX 2080. Changes in core/memory speeds as well as increases to GPU PPC (Performance Per Clock), should give Nvidia’s next-generation Ampere designs further performance gains.
Nvidia’s RTX 3070 Ti/Super is also said to feature a 250W TGP, which is 30W higher than Nvidia’s rumoured RTX 3070. This power difference should boost the RTX 3070 Ti’s performance lead. The RTX 3070 Ti has more power and more CUDA cores than the RTX 3070.
| RTX Titan (Ampere) | RTX 3090 /3080 Ti |
RTX 3080 | RTX 3070 Ti/Super | RTX 3070 |
Titan RTX (Turing) | RTX 2080 Ti | RTX 2080 Super | RTX 2080 | RTX 2070 Super | RTX 2070 | |
| GPU | GA102-400 | GA102-300 | GA102-200 | GA104-400 | GA104-300 | TU102-400 | TU102-300 | TU104-450 | TU104-400 | TU104-410 | TU106-400 |
| CUDA Cores | 5376 | 5248 | 4352 | 3072 | 2944 | 4652 | 4352 | 3072 | 2944 | 2560 | 3204 |
| Memory | 24GB GDDR6X | 12GB GDDR6X | 10GB GDDR6X | 8GB GDDR6/X | 8GB GDDR6/X | 24GB GDDR6 | 11GB GDDR6 | 8GB GDDR6 | 8GB GDDR6 | 8GB GDDR6 | 8GB GDDR6 |
| Memory Speed | 17Gbps | 21Gbps | 19Gbps | ? | ? | 14Gbps | 16Gbps | 15.5 Gbps | 14 Gbps | 14Gbps | 14Gbps |
| Memory Bus | 384-bit | 384-bit | 320-bit | 256-bit | 256-bit | 384-bit | 352-bit | 256-bit | 256-bit | 256-bit | 256-bit |
| Memory Bandwidth | 816GB/s | 1008GB/s | 760 GB/s | ? | ? | 672 GB/s | 616 GB/s | 496 GB/s | 448GB/s | 448GB/s | 448GB/s |
Nvidia’s Ampere architecture should deliver Nvidia major gains in graphics performance over Turing, especially if Nvidia has managed to increase the core clock speeds of their next-generation graphics cards. Architectural improvements should also see Nvidia’s AI and ray-tracing performance increase, factors which will be highly beneficial for next-generation titles.
Like all graphics card rumours, please take this information with a grain of sail. Remember that nothing is “confirmed” until Nvidia officially reveals it.
You can join the discussion on Nvidia’s rumoured RTX 3070 Ti and RTX 3070 specifications on the OC3D Forums.
