AOC launched sub 200 pound 144Hz FreeSync monitor
AOC launched sub £200 144Hz FreeSync monitor
AOC has launched a sub £200 1080p 144Hz FreeSync monitor, which is 100 pound cheaper than it’s G-Sync equivalent the AOC G2460PG.
Both monitors sport nigh identical specifications, with both the FreeSync and the G-Sync models sporting the same 1080p 144Hz TN panel with a 800000000:1 contrast ratio, 350cd/m^2 brightness and the same 1ms response time. To the eyes of this writer the only differences between both of these monitors is which adaptive display standard that they support.
[AOC G2460PF FreeSync monitor £199 (Left) and AOC G2460PG G-Sync monitor £299.99 (Right)]
“Designed for serious gamers, the 24-inch AOC G2460PF display delivers an extra smooth playing experience with AMD FreeSync™. Combined with an AMD Radeon™ graphics card and AMD Catalyst™ driver, FreeSync™ seamlessly synchronizes the monitor and GPU refresh rates to eliminate tearing, stuttering and input lag. Ultra fast 1ms response time and impressive 144Hz refresh rate diminish distractions like blurring and ghosting that can mean the difference between victory and defeat. Whether you’re racing around the track or stalking enemies in a first-person shooter, the Full HD resolution delivers sharp, true-to-life imagery.
Goodbye motion blur! Equip yourself with twice the frame rate of other monitors and forget enemies that appear to stutter across your screen, making them difficult targets to hit. With a 144Hz frame rate, you see those critical missing images on the screen, showing your foe’s movement in ultra smooth motion and eliminating blur and tearing. Games are too good to go unseen.
A pixel response time of 1 ms means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of ghosting. Choose the right path to success, don’t let a slow display stop you.”
Specifications:
– AMD FREESYNC Technology
– Monitor Size: 24″
– Visible Screen Size: 61 cm
– Screen Format: 16:9
– Brightness: 350 cd/m² (typ)
– Contrast Ratio Dynamic: 80.000.000:1
– Contrast Ratio Typical: 1000:1
– Viewing Angle: 178°/170° (CR 10)
– Response Time: Up to 1 ms GtG
– Maximum Resolution: 1920 x [email protected] Hz (DVI Port)
– Scanning frequency: H: 30-83 KHz (30-160 KHz DVI-D) / V: 50-76 Hz (50-146 Hz DVI-D)
– Recommend Resolution: 1920 x [email protected] Hz (DP/DVI-D)
– Colors: 16.7 M
– HDCP compatible: yes
– Height adjust, pivot & swivel
– Inputs: DisplayPort, DVI-D, HDMI & Analogue
– Warranty: 3yr
Right now the only problem which I have with this monitor is that the manufacturer has not disclosed this monitors adaptive refresh rate range, leaving us consumers in the dark as to this monitor’s adaptive refresh rate capability.
Hopefully this monitor will have a wide range of around 30-144Hz, but at this time we simply do not know. We hope that this information will become available before stock of this monitor arrives in the UK.
You can join the discussion on AOC’s sub £200 1080p 144Hz FreeSync monitor on the OC3D Forums.
AOC has launched a sub £200 FreeSync monitor, which is £100 cheaper than the G-Sync version. http://t.co/3PWgYa6mqX pic.twitter.com/hTqjwDFYhC
— OC3D (@OC3D) September 14, 2015
