ASUS releases their ProArt PA27AC DisplayHDR 400 monitor
ASUS releases their ProArt PA27AC displayHDR 400 monitor
This display comes pre-calibrated from the factory, making it suitable for professional use, though ASUS has integrated their ProArt Calibration technology to allow users to quickly calibrate their screen and save their colour profiles on the display itself to allow it to be used with multiple devices recalibration.
The PA27AC meets VESA’s requirements for DisplayHDR 400, a new HDR standard that acts as the minimum requirements for HDR, specifying a peak luminance of 400 nits, 8-bit image quality and standard dynamic contrast dimming. Sadly this is a far cry from what a full HDR 10 panel would support, which specifies a maximum brightness of 1,000 nits, a 10-bit panel with 125% sRGB or 90% DCI-P3 colour support and local dimming to offer enhanced contrast.
The ASUS PA27AC support AMD FreeSync out of the box, with a dynamic refresh rate window of 48-60Hz, which is extremely limited. Input-wise the PA27AC supports DisplayPort, USB Type-C/Thunderbolt 3 (1 in and 1 out), HDMI 2.0 and HDMI 1.4. The display also supports a QuickFit feature to show the dimensions of an A4 page, a B5 page, and a ruler to allow users to scale documents or images to their real-world sizes.
Like many other professional displays that PA27AC supports adjustments using the display’s swivel, pivot, tilt and height adjustment options, making this monitor suitable for almost any working environment. The display is also designed to support standard VESA mounts for use with monitor arms or 3rd party stands.
You can join the discussion on ASUS’ ProArt PA27AC DisplayHDR 400 monitor on the OC3D Forums.
