ASUS Release Ultra Low Power GTX 950 with no PCIe Power
ASUS has released a new version of their GTX 950, one that has a decreased TDP and doesn’t require a PCIe power connection, allowing the GPU to run at reference GTX 950 speeds without the need for more power than the PCIe lane on your motherboard can provide.
The original GTX 950 had a TDP of 90W, requiring a PCIe power connector as it is consumed more than the 75W power that can come from a PCIe lane. ASUS’ new version of the GTX 950 has a reduced TDP, allowing the GPU to run without a 6-pin power connector.
Below are the full specification of ASUS’ new GTX 950;
  • – Graphics Engine: NVIDIA GeForce GTX 950
  • – Interface: PCI Express 3.0
  • – Video Memory: GDDR5 2GB
  • – CUDA Cores: 768
  • – Memory Clock: 6610 MHz
  • – Memory Interface: 128-bit
  • – Engine Clock
    • – Gaming Mode (Default) – GPU Boost Clock : 1190 MHZ , GPU Base Clock : 1026 MHz
    • – OC Mode – GPU Boost Clock : 1228 MHZ , GPU Base Clock : 1051 MHz
  • – Interface: HDMI 2.0, DisplayPort, DVI
  • – Power Consumption: Up to 75W,
  • – Dimensions: 8.3 x 4.5 x 1.6 inches
Right now we do not have a clear release date for this product in the UK, but it is expected to be on store shelves soon. This GPU features a 15w reduction in TDP, which is an almost 17% reduction in power consumption.
You can join the discussion on ASUS’ new low power GTX 950 on the OC3D Forums.
