Inno3D Introduces The WAVE Passive Cooling Solution
News Posted 28/02/07
Author: PV5150
Source: VR-Zone
InnoVISION Multimedia Limited has introduced the WAVE passive cooling solution to their Inno3D mainstream 7 series. Now we all know that the main advantage for passive cooling is that it generates zero noise.
According to the source, the main features for the Inno3D Wave design include:
| 1. Curve Wave design – uniquely designed to penetrate heat from top to bottom of the PCB and also circulates heat in and out. (Refer to the diagram) 2. Clipping Arm – is clipped securely onto the top part of the PCB in order to help absorb heat (Refer to the diagram) 3. Double sided Aluminum Extrusion Fins – increases surface area consecutively to radiate heat efficiently (Refer to the diagram) 4. Raise specific heat capacity – lowers temperature increment i.e. is the measure of the heat energy required to raise the temperature of a specific quantity of a substance by a certain amount. |
According to the manufacturer, the Wave is ready and equipped on their mainstream 7 series.
Feel free to comment in our forum
