LG showcases a 65-inch rollable display
LG has demonstrated a “rollable” screen technology, a device that can be rolled up like a newspaper to fit into a compact box, out of sight and out of mind. The screen in the images shown above and below is a 65-inch OLED panel with a 4K resolution, making this a high-quality display, not just a rollable display.
The advantages of this screen type are obvious, as the unit itself is very easy to store and transport. The box-like base can also hold a secondary purpose as a soundbar, containing higher quality speakers than most standard flat panel televisions.
This display is a prototype, so don’t expect this television to grace store shelves anytime soon, as it opens up the possibility of consumer products that would have been considered sci-fi just a few short years ago.
You can join the discussion on LG’s rollable 65-inch 4K display on the OC3D Forums.
