Nvidia announces mobile variants of their GTX 1050 and 1050Ti GPUs
Below is a table that lists the specifications of Nvidia’s GTX 1050 and GTX 1050Ti, highlighting the difference between their mobile and desktop versions.
Both desktop and mobile GTX 1050/1050Ti GPUs will be made on the same Samsung 14nm FinFET manufacturing process. As you can see in the table below Nvidia’s GTX 1050Ti gets a significant clock speed increase on mobile, which should allow it to perform like an overclocked desktop variant.
| GTX 1050 Desktop | GTX 1050 Mobile | GTX 1050Ti Desktop | GTX 1050Ti Mobile | GTX 1060 6GB | |
| Manufacturing node | 14nm | 14nm | 14nm | 14nm | 16nm (TSMC) |
| CUDA Cores | 640 | 640 | 768 | 768 | 1280 |
| Base Clock | 1354MHz | 1354MHz | 1290MHz | 1493MHz | 1404MHz |
| Boost Clock | 1455MHz | 1493MHz | 1392MHz | 1602MHz | 1670MHz |
| Memory Bus | 128-bit | 128-bit | 128-bit | 128-bit | 192-bit |
| Memory Clock | 7000MHz | 7000MHz | 7000MHz | 7000MHz | 8000MHz |
| Memory Type | GDDR5 | GDDR5 | GDDR5 | GDDR5 | GDDR5 |
| Memory Cappacity | 2GB | Up to 4GB | 4GB | Up to 4GB | 6GB |
CES 2017 will be filled with new notebooks which carrying Nvidia’s new GTX 1050 series mobile GPUs, offering Pascal GPUs to a whole new section of the market. It is expected that Nvidia will make additional announcements at their CES keynote on January 5th at 2.30am GMT.
You can join the discussion on Nvidia’s GTX 1050 series of mobile GPUs on the OC3D Forums.
