Nvidia’s RTX 3080 will reportedly be 20% faster than an RTX 2080 Ti
At this time, we cannot confirm the validity of these specifications. Details of the Ampere series remain unknown to most Nvidia employees, making the best response from practically all Nvidia representatives be the industry standard “we don’t comment on rumours”. Take these specifications with a grain of salt, as while they have been independently reported by two sources, @KkatCorgi and @kolite7kimi, it is possible that these specifications originated from a single, possibly false, source.
RTX 3080
It has now been reported by @KkatCorgi that Nvidia’s upcoming RTX 3080 will offer (approximately) a 20% performance boost over Nvidia’s RTX 2080 Ti. At this time it is unknown what workload was used to measure this change, or if this performance boost is an average that was taken across multiple workloads using an RTX 3080 test sample.
If the already leaked specifications of Nvidia’s RTX 3080 are correct, Nvidia will be offering its users the same number of CUDA cores as their RTX 2080 Ti. With faster memory, architectural advancements and (potentially) higher clock speeds, a 20% performance gain should be more than possible for Nvidia’s next-generation architecture.
At this time, no memory producer has revealed GDDR6X memory, which is something which casts a lot of doubt onto these rumoured specifications. That said, GDDR6X could be a brand name for faster than normal GDDR6 memory, similar to how HBM2E memory is just a faster version of normal HBM2 memory.
With Nvidia’s RTX 2080 Ti being both bandwidth and power-constrained in many of today’s games, it is easy to see how Ampere has the potential to deliver significant performance improvements over Turing. Smaller process tech and architectural enhancements will increase Ampere’s efficiency, performance per clock cycle, and raw clock speeds over Nvidia’s Turing-based RTX 2080 Ti. These factors should make Ampere a lot more powerful than Turing, at least on the high-end.
Below are a set of leaked specifications for Nvidia’s RTX 30 series of high-end GPUs.
| RTX Titan (Ampere) | RTX 3090 /3080 Ti |
RTX 3080 | Titan RTX (Turing) | RTX 2080 Ti | RTX 2080 Super | RTX 2080 | |
| GPU | GA102-400 | GA102-300 | GA102-200 | TU102-400 | TU102-300 | TU104-450 | TU104-400 |
| CUDA Cores | 5376 | 5248 | 4352 | 4652 | 4352 | 3072 | 2944 |
| Memory | 24GB GDDR6X | 12GB GDDR6X | 10GB GDDR6X | 24GB GDDR6 | 11GB GDDR6 | 8GB GDDR6 | 8GB GDDR6 |
| Memory Speed | 17Gbps | 21Gbps | 19Gbps | 14Gbps | 14Gbps | 15.5 Gbps | 14 Gbps |
| Memory Bus | 384-bit | 384-bit | 320-bit | 384-bit | 352-bit | 256-bit | 256-bit |
| Memory Bandwidth | 816GB/s | 1008GB/s | 760 GB/s | 672 GB/s | 616 GB/s | 496 GB/s | 448GB/s |
At this time, Nvidia has said nothing about their consumer-grade RTX Ampere series of graphics cards, so take these specifications with a massive grain of salt. That said, these specifications lie well within expectations for the RTX 30XX series, assuming that GDDR6X memory exists.
You can join the discussion on Nvidia’s RTX 3080 on the OC3D Forums.
