Phanteks launches White Gen4 PCIe Riser Cables and a White Vertical GPU bracket
Want to vertically mount your GPU? Phanteks has some products for you
Phanteks’ PCIe 4.0 riser cables and Vertical GPU Bracket are now available in white, giving PC builders colour matching cable and riser card options for users of white PC cases. Phanteks’ PCIe 4.0 riser cables are available with straight and right-angled PCIe connection options, making these cables compatible with a wide range of PC cases and custom enclosures.
While Phanteks’ PCIe 4 vertical GPU brackets are designed for the company’s P300A, P360A, and P400A cases, most ATX cases can support this bracket natively or though modding.
    The Vertical GPU bracket and riser cables now introduce a white colour option, matching our white chassis for better harmony and overall style. The reinforced steel now provides reliable support eliminating any sagging also includes PCI-e Gen 4 riser cable for new-gen Graphic cards. Finally, our Flat Line PCI-E Gen 4 Riser Cables are available in white, giving you the power to unlock the full potential of any high-end Gen 4 Graphic Cards. Dual-layer design improves the performance and stability of the high bandwidth signals while the individual lane is shielded from EMI/EFI interference to prevent interference between channels.
Phanteks’ new white PCIe 4.0 riser cables and vertical GPU mount are available starting this month at the following prices.
– Gen 4 Vertical GPU Bracket, White: $69.99 / €69.90 / £60.90
– Flat Line 220 mm PCIe Gen 4 Riser Cable 90 White: $59.99 / €59.90 / £52.90
– Flat Line 300 mm PCIe Gen 4 Riser Cable 180 White: $59.99 / €59.90 / £52.90
You can join the discussion on Phanteks’ white PCIe 4 riser cables and vertical GPU mount on the OC3D Forums.
