PowerColor Radeon RX 9070 XT Red Devil Spectral White GPU Leaks
PowerColor’s making an all-white Radeon RX 9070 XT Red Devil GPU
Last week, we reviewed PowerColor’s Spectral White Radeon RX 9070 XT Hellhound, which is a fantastic-looking graphics card. Now, it looks like PowerColor is building Spectral White versions of their Radeon RX 9070 XT Red Devil, which also looks marvellous.
Videocardz was the first to report on this new all-white Radeon graphics card. The GPU has the same design and specifications as its black counterpart, which means that this new Spectral White variant will also be at the top of PowerColor’s AMD RDNA 4 GPU lineup.
(Image from Videocardz)
With a white heatsink, white shroud, white fans, and a white PCB, the Spectral White PowerColor RX 9070 XT is a master class in how white PC hardware should be built. Even its I/O shield is white.
Given that this GPU has the same specifications as its non-White counterpart, gamers can expect it to have a TDP of 340W and game/boost clock speeds of 2,520/3,060 MHz in OC mode.
In the UK, PowerColor’s standard Radeon RX 9070 XT Red Devil costs £719.99. We expect the GPU’s Spectral White variant to cost the same when it becomes available.
You can join the discussion on PowerColor’s Radeon RX 9070 XT Red Devil Spectral White GPU on the OC3D Forums.
