Apacer Blade Fire DDR4-3200 32GB Memory
Apacer Blade Fire DDR4 3200MHz 32GB Memory kit
Apacer have revealed their new Blade Fire DDR4 memory, featuring Rad LED illumination, speeds of up to 3200MHz and capacities of up to 32GB.
These new BLADE FIRE modules are available in 4 GB, 8 GB, and 16 GB capacities, which allows dual-module packages to have up to 32GB of capacity.  These modules will start at 2400MHz at 1.2v and will be available in speeds of up to 3200MHz at 1.35v.
Apacer Blade Fire DDR4-3200 32GB Memory  Apacer Blade Fire DDR4-3200 32GB Memory
These memory sticks feature pulsing, heartbeat LEDs which beat at a rate of 44 beats per minute while still maintaining very high memory efficiency and speeds.
These modules support Intel XMP 2.0 and fully supports Intel’s Z170 Skylake platform, meaning that all the user needs to do is simply plug these modules in and enable Intel XMP in order to achieve the full speeds of this memory.
Right now we do not have the UK price of these memory kits or availability information for the UK.
You can join the discussion on Apacer’s new Blade Fire DDR4 memory on the OC3D Forums.
