Corsair release 128GB, 64GB and 32GB DDR4 kits
Corsair have just released their new release 128GB, 64GB and 32GB DDR4 LPX memory kits, which have speeds of up between 3000MHz and 3600MHz.
Most of these kits will be available in red and black, giving you enough choice to match most motherboards out there, though it would be nice to see some other colours become available in the future, at least for their basic kits.
   Corsair release 128GB, 64GB and 32GB DDR4 kits  Corsair release 128GB, 64GB and 32GB DDR4 kits
All these kits are XMP 2.0 compatable and are ready for use in Intel’s X99 Haswell-E and Z170 Skylake platforms, with all DIMMS in a set being tested and fully matched so that they will run flawlessly right out of the box.
All three of these new kits will also be shipped with an Corsair’s Airflow fan system, which provides adequate airflow to keep you memory cool regardless of your system loads.
Corsair say that these DIMMs are designed for 3D rendering and 4K content creation, offering huge capacities at high speeds so that you can do a lot of work quickly.
 All of these kits are available from the Corsair website and are available at select retailers.
You can join the discussion on Corsair’s new 32-128GB DDR4 memory kits on the OC3D Forums.
