G.SKILL 4x16GB DDR4-3200MHz RAM Kits 64GB!
G.SKILL 4x16GB DDR4- 3200MHz RAM Kits 64GB!
G.SKILL now sell consumer RAM kits with up to 64GB of storage capacity at speeds of 3200MHz and up to 16GB of cappacity per DIMM. This will allow system builders on X99 to have a system with up to 128GB of DDR4 memory, which is simply insane for the majority of users.
These new DIMMs will have a frequency of up to 3200MHz and CL timings as low as 14-14-14-34 at voltages of 1.35V, which is amazing given how most DDR3 memory requires 1.5V for a mere frequency of 1600MHz.
G.SKILL 4x16GB DDR4-3200MHz RAM Kits 64GB!  G.SKILL 4x16GB DDR4-3200MHz RAM Kits 64GB!
This memory will be available as pictured above and below, with red, black or with the TridentZ red and gray heatsinks, which would look great with a wide range of modern motherboards.
These modules have been Validated on Intel’s latest Z170 platfrom with a i7-6700K and will feature Intel XMP 2.0 profiles for easy use, allowing this high speed, high capacity modules to be used with ease.
G.Skill’s 64GB DDR4 kits which are rated to operate at DDR4-3200MHz with CL15 15-15-35 timings will cost $499.99 in the U.S with the 64GB DDR4-3200 kit with faster CL14 14-14-34 timings will be priced at $579.99.
These kits are very expensive, but right now it is very hard to argue with what you get here in terms of capacity and speed.
You can join the discussion on G.Skills 4x16GB DDR4 3200MHz memory kits on the OC3D Forums.
