Xbox confirms 10x Ray Tracing boost with Project Helix
Xbox promises huge CPU and GPU performance uplifts with its next-generation Xbox console
At GDC 2026, Microsoft has been shedding some light on its next-generation Xbox console, codenamed Project Helix. Microsoft’s Jason Ronald has confirmed that Project Helix will have an “order of magnitude increase in ray tracing performance and capability”. This places Microsoft’s next Xbox far ahead of Xbox Series S and X.
With an “order of magnitude” of extra ray tracing performance, Microsoft has promised a 10x increase in ray tracing performance over Xbox Series X. Furthermore, Microsoft has confirmed that its console will feature improved CPU performance thanks to GPU-directed work graphs.
With Work Graph Execution, GPUs can generate their own work without a CPU acting as taskmaster. This reduces CPU strain and allows CPU resources to be allocated more efficiently. It also prevents GPU workloads from becoming CPU-constrained. At GDC 2024, AMD showcased Work Graph Execution and demonstrated how it could deliver 40% performance gains in a test environment.
Beyond the SOC, it (Project Helix) also includes an order of magnitude increase in ray tracing performance and capability, beyond what’s currently possible with the Xbox Series X and S.
It also unlocks GPU-directed work graph execution, eliminating CPU bottlenecks. This means that the GPU can actually generate its own workloads in real time. This delivers a massive uplift in performance and enables massive real-time simulations in large complex worlds using runtime-generated geometry and large-scale interactive worlds that players want to engage with.
– Xbox’s Jason Ronald at GDC 2026
It’s not just new hardware, it’s how you use it
Microsoft isn’t just relying on enhanced ray tracing performance to give Project Helix the next-generation performance boost it needs. Microsoft’s also utilising new technologies to more efficiently utilise their hardware. GPU-based Work Graph Execution is one example of this. Other examples include next-generation ML upscaling, multi-frame generation, and neural texture compression.
Technologies like “next-gen Ray Regeneration” will also allow Microsoft’s new ray tracing hardware to be utilised more effectively. Microsoft is combining a 10x boost in ray tracing performance with a technology that enables stronger visual returns with fewer ray casts. That will have a multiplying effect on Microsoft’s overall ray tracing capabilities.
Today’s consoles introduced ray tracing to the masses. With Project Helix, ray tracing should become the norm. Strong ray tracing hardware with an enhanced feature set and ML-enhanced software. Project Helix will introduce the next generation of ray tracing capabilities on consoles.
You can join the discussion on Xbox’s next-generation Project Helix console on the OC3D Forums.
