Bandai Namco release TEKKEN 7’s PC system requirements
Bandai Namco release TEKKEN 7's PC system requirements
The PC system requirements for TEKKEN 7 have been announced, revealing exactly how powerful your system will need to be to play the game.
Tekken 7 will require a 64-bit OS with at least 6GB of and a CPU with 4 threads. The game’s PC system requirements list the game as a DirectX 11 title, requiring a minimum of a GTX 660 or a GTX 750 Ti to play, with no AMD GPUs listed in the game’s requirements.
Below are the full PC system requirements for TEKKEN 7, though sadly there are no AMD system requirements listed on both the CPU and GPU side.
MINIMUM:
    • OS: Windows 7/8/10 (64-bit OS required)
    • Processor: Intel Core Intel Core i3-4160 @ 3.60GHz or equivalent
    • Memory: 6 GB RAM
    • Graphics: NVIDIA GeForce GTX 660 2GB, GTX 750Ti 2GB, or equivalent
    • DirectX: Version 11
    • Network: Broadband Internet connection
    • Storage: 60 GB available space
    • Sound Card: DirectX compatible soundcard or onboard chipset
RECOMMENDED:
    • Processor: Intel Core i5-4690 3.5 GHz or equivalent
    • Memory: 8 GB RAM
    • Graphics: NVIDIA GeForce GTX 1060 equivalent or higher
    • You can join the discussion on TEKKEN 7’s PC system requirements on the OC3D Forums.
MINIMUM:
    • Memory: 6 GB RAM
RECOMMENDED:
    • Memory: 8 GB RAM
