Bethesda announce Prey’s PC system requirements
Bethesda announce PREY's PC system requirements
Bethesda announce PREY’s PC system requirements
Bethesda has now released Prey’s PC system requirements, as well as a list of PC graphical options. The PC version of this game will require a minimum of an Intel i5 2400 or an AMD FX 8320, and either a GTX 660 or an HD 7850.
When it comes to system memory this game will require a minimum of 8GB, with the game also requiring at least 2GB or VRAM.
PC ADVANCED SETTINGS
  • – Object Detail
  • – Shadow Quality
  • – Texture Quality
  • – Anisotropic Filtering
  • – Anti-Aliasing
  • – Horizontal Field of View
  • – Screen Space Directional Occlusion
  • – Screen Space Reflections
Below are Prey’s official PC system requirements.
PC SYSTEM REQUIREMENTS
Minimum
CPU: Intel i5-2400, AMD FX-8320
GPU: GTX 660 2GB, AMD Radeon 7850 2GB
Memory: 8 GB
Recommended
CPU: Intel i7-2600K, AMD FX-8350
GPU: GTX 970 4GB, AMD R9 290 4GB
Memory: 16 GB
Prey will release on PC, Xbox One and PS4 on May 5th.
You can join the discussion on Prey’s PC system requirements on the OC3D Forums.
  • – Object Detail
  • – Shadow Quality
  • – Texture Quality
  • – Anti-Aliasing
Minimum
Memory: 8 GB
Recommended
Memory: 16 GB
