Bungie releases Destiny 2’s PC system requirements and beta dates
Bungie releases Destiny 2's PC system requirements and beta dates
The PS4 and Xbox One betas for Destiny 2 are over, leaving PC as the only platform that lacks any form of pre-release beta/demo content. Now Bungie, the developer behind the game, has revealed that the game’s PC beta will take place at the end of August.
This will be an open beta, though those who pre-order the game will be able to play it in a day early, giving them some additional time to play the game. Below are the start dates for Destiny 2’s PC beta.
Destiny 2 PC Beta
Early Access: August 28
Open Beta: August 29
Beta Ends: August 31
Below are the PC system requirements for Destiny 2’s PC beta, though these requirements are likely to change as the game is developed further.
Recommended Spec
CPU – Intel – Core i5-2400 or AMD – Ryzen R5 1600X
GPU – Nvidia – GeForce GTX 970 or AMD – Radeon R9 390
RAM – 8GB
Minimum Spec
CPU – Intel – Core i3-3250 or AMD – FX-4350
GPU –Nvidia GeForce GTX 660 2GB or AMD Radeon HD 7850 2GB
RAM- 6GB
Destiny 2 will release on PC on October 24th.
You can join the discussion on Destiny 2’s PC beta on the OC3D Forums.
Destiny 2 PC Beta
Recommended Spec
RAM – 8GB
Minimum Spec
RAM- 6GB
