Creative Assembly releases Total War: Warhammer 2’s PC system requirements
Creative Assembly releases Total War: Warhammer 2's PC system requirements
Creative Assembly has officially revealed Total War Warhammer II’s PC system requirements, giving PC gamers some basic guidelines for how well the game will perform.
The company has also detailed some of the graphical improvements that will be coming to the game, including improved Screen Space Ambient Occlusion, a new volumetric fog system, a new “sharpening filter” and impressive effects for “wet-look” surfaces.
Sadly, Creative Assembly has not detailed any changes to the game’s DirectX 12 version, which remains as a “beta” option for the original Total War: Warhammer.
Creative Assembly has also confirmed that Total War: Warhammer II is the most pre-ordered Total War game to date, showcasing just how much confidence fans have in the company’s latest product.
Continuing the series trend for optimisation and performance improvement, the second game in CA’s fantasy-strategy trilogy will be playable on a wide range of PC systems. To achieve the gameplay gold-standard of 60FPS, Creative Assembly has also quoted a 60FPS @ 1080P spec alongside the minimum and recommended specs below.
Below are creative Assembly’s PC system requirements for Total War Warhammer II, which showcase how scalable this game can be on PC.
PC Recommended Specifications:
Expected around 45-55 FPS on campaign map and in a 1v1, 20 units vs 20 units battle, default graphics preset set to “High”, running at 1920×1080
Operating System: Windows 7/8.1/10 64Bit
Processor: Intel® Core™ i5-4570 3.20GHz
RAM: 8
GBInstall size: 60 GB
Video Card: NVIDIA GeForce GTX 760 2GB | AMD Radeon R9 270X 2GB @1080P
PC Minimum Specifications:
Expected around 25-35 FPS on campaign map and in a 1v1, 20 units vs 20 units battle, default graphics preset set to “Low”, running at 1280×720
Operating System: Windows 7 64Bit
Processor: Intel® Core™ 2 Duo 3.0Ghz
RAM: 4GB/5GB*
Install size: 60 GB
Video Card: NVIDIA GTX 460 1GB | AMD Radeon HD 5770 1GB | Intel HD4000 @ 720p
*PC integrated graphics chipsets, e.g. Intel HD series, will require 5GB system RAM
PC 60fps Specifications:
Expected 60 FPS on campaign map and in a 1v1, 20 units vs 20 units battle, default graphics preset set to “Ultra”, running at 1920×1080
Processor: Intel® Core™ i7-4790K 4.0 GHz
RAM: 8 GB
Install size: 60 GB
Video Card: Nvidia GTX 1070 8GB
Please note: all systems perform differently. The framerates above are based on PCs using the quoted specs with fresh OS installs, no major background programs running, and should be taken as a guide rather than an absolute.
All graphical settings in Total War: Warhammer II can be manually customised if the player wishes. Below is a list of the settings used in each of the game’s default graphical presets.
Setting Name Low Medium High Ultra
Direct X DX11 DX11 DX11 DX11
Anti-aliasing Off Off Off FXAA
Texture Filtering Trilinear Anisotropic 4x Anisotropic 8x Anisotropic 16x
Texture Quality Low Medium High Ultra
Screen Space Ambient Occlusion Off Off Off On
Depth of Field Off Off Off Off
Screen Space Reflections Off Off Off Off
Unit Detail Low Medium High Ultra
Building Detail Low Medium High Ultra
Shadow Detail Low Medium High Ultra
Tree Detail Low Medium High Ultra
Grass Detail Low Medium High Ultra
Water Detail Low Medium High Ultra
Unit Size Small Medium Large Ultra
VFX Detail Low Medium High Ultra
Terrain Detail Low Medium High Ultra
V-Sync Off Off Off Off
Vignette Off Off Off Off
Proximity Fading On On On On
Fog Low Low High High
Resolution Scale 100% 100% 100% 100%
UI Scale 100% 100% 100% 100%
Unlimited Video memory Off Off Off Off
Porthole quality 2D 3D 3D 3D
Total War: Warhammer II will release on PC on September 28th.
You can join the discussion on Total War: Warhammer II on the OC3D Forums.
RAM: 8
GB Install size: 60 GB
RAM: 4GB/5GB*
Install size: 60 GB
RAM: 8 GB
Install size: 60 GB
