EA reveals A Way Out’s PC system requirements
A Way Out is a game which is set to deliver a unique co-op only gaming experience, where two players, either offline or online, control one of the game’s two protagonists.
These PC requirements come one day before the game’s official PC launch, though thankfully the game’s hardware needs are relatively low, at least on the Nvidia side of the spectrum.
One oddity with this release is an apparent lack of keyboard/mouse support, with the game’s requirements explicitly requesting an Xbox or PlayStation compatible gamepad, with no mention of mouse/keyboard. Given the two-player nature of this game, gamepad support was expected to take centre stage, though a lack of keyboard/mouse support will be nonetheless disappointing.
For 720p Low settings, EA recommends that PC gamers have an Intel i3 2100 or an FX 6100 CPU or higher alongside 8GB of system memory and an HD7750 or a GTX 650 Ti GPU. The game will also take up 25GB of hard drive space.
Moving onto the game’s recommended PC setup, which should run the game at 1080p 60FPS, EA has listed an i5 3570K or a Ryzen 3 1300X or higher with 16GB of system memory and either an R9 290 or a GTX 960 GPU. The game’s recommended system requirements seem slanted towards Nvidia, as AMD’s R9 290 was pitted up against Nvidia’s GTX 970 at the time of its release.
EA has also provided a selection of settings for 1080p 60FPS gameplay when using a system that is based on their recommended system requirements.
MINIMUM PC REQUIREMENTS: 720P 30 FPS AT LOW SETTINGS
O/S: Windows 7 64-bit, 8.1 64-bit or Windows 10 64-bit
CPU: Intel core i3-2100T @ 2.5GHz/AMD FX 6100, or better
RAM: 8GB
GPU: NVIDIA GeForce GTX 650Ti 2GB, AMD Radeon HD 7750 2GB
DirectX: 11 Compatible video card or equivalent
Hard Drive: 25GB
Input: At least one Xbox-compatible/PlayStation-compatible controller
Online connection requirements: 256KBPS or faster Internet connection
RECOMMENDED PC REQUIREMENTS: 1080P 60 FPS AT HIGH SETTINGS
RAM: 16GB
CPU: Intel Core i5 3570K; AMD Ryzen 3 1300x or equivalent
GPU: Nvidia GT 960; AMD R9 290 or equivalent
Hard Drive: 25GB
VIDEO SETTINGS: 60 FPS 1080P
Display Mode: Fullscreen
Resolution: 1920×1080
Vsync: Off
Texture Quality: High
Shadow Quality: Med
Reflection Quality: High
Detail Level: Medium
Shader Quality: Medium
Water Simulation: High
Anisotropic Filtering: 8X
Post Processing Quality: High
Gamma: 50
A Way Out will release on Origin on March 22nd with a price of £24.99 and $29.99 in the UK and the US respectively.
You can join the discussion on A Way Out’s PC system requirements on the OC3D Forums.
