FromSoftware Releases Sekiro: Shadows Die Twice’s PC System Requirements
When compared to Dark Souls 3, FreomSoftware’s last major PC release, Sekiro delivers a moderate increase in PC system requirements, upping the game’s minimum graphics card from a GTX 750 Ti to a GTX 760 and the game’s recommended CPU from a AMD FX-8350 to a Ryzen 5 1400, a processor that boasts significantly improved single-threaded performance.
In other regards, Sekiro: Shadows Die Twice is exceptionally similar to Dark Souls 3, boasting the same storage and memory requirements. Strangely, on the Intel-side, Sekiro has lower recommended CPU requirements m moving from an i7-3770K to an i5-2500K, which is great news for PC gamers, as this is a sign that FromSoftware’s game engine now boasts improved CPU efficiency on PC.
Below is Sekiro: Shadows Die Twice’s full PC system requirements, which are fairly low when compared to a lot of modern AAA releases.
MINIMUM:
OS: Windows 7 64-bit | Windows 8 64-bit | Windows 10 64-bit
Processor: Intel Core i3-2100 | AMD FX-6300
Memory: 4 GB RAM
Graphics: NVIDIA GeForce GTX 760 | AMD Radeon HD 7950
DirectX: Version 11
Network: Broadband Internet connection
Storage: 25 GB available space
Sound Card: DirectX 11 Compatible
RECOMMENDED:
Processor: Intel Core i5-2500K | AMD Ryzen 5 1400
Memory: 8 GB RAM
Graphics: NVIDIA GeForce GTX 970 | AMD Radeon RX 570
DirectX: Version 11
You can join the discussion on Sekiro: Shadows Die Twice’s PC System Requirements on the OC3D Forums.
