Here’s what you need to run Ubisoft’s Hyper Scape Technical Test on PC
Here’s what you need to run Ubisoft’s Hyper Scape on PC
Currently, Ubisoft’s latest shooter is available on PC as a “technical test”, which can be accessed by selected players through Twitch Drops or via online registration. Registering for the game will not automatically grant players early access.
Hyper Scape will be available as a free-to-play game when it officially releases, offering players fast-paced combat and plenty of close-quarters combat. At this time the game has no firm release date for PC, though Ubisoft has provided a set of early PC system requirements for the game, which are designed to showcase what hardware is required for 1080p 60FPS gameplay and 4K 60 FPS gameplay.
PC gamers will be glad to know that this game will be playable on systems with graphics cards as old as Nvidia’s GTX 660 and AMD’s Radeon HD 7870 with 1080p 60FPS gameplay. These framerate targets suggest that Hyper Scape’s planned console versions will also target 60 FPS gameplay.
PC gamers can sign up for Hyper Scape’s technical test here. This test will be playable until July 8th at 8 AM BST.
Below are the Hyper Scape’s early PC system requirements.
Minimum Spec: (Low settings, 1080p @ 60fps)
CPU – Intel Core i3 3220 or AMD FX-4130
DRAM – 6 GB RAM
GPU – Nvidia GTX 660 or AMD Radeon HD 7870 with 2 GB dedicated VRAM
Recommended Spec: (High settings, 1080p @ 60fps)
CPU – Intel Core i7 4790 or AMD Ryzen 5 1500X
DRAM – 8 GB RAM
GPU – Nvidia GTX 970 or AMD Radeon RX 480 with 4 GB dedicated VRAM
High Spec: (Ultra High settings, up to 4K @ 60fps)
CPU – Intel Core i9 7900 X, AMD Ryzen 5 PRO 3600
DRAM – 16 GB RAM
GPU – Nvidia 2080Ti or AMD Radeon RX 5700 XT with 11 GB dedicated VRAM
You can join the discussion on Hyper Scape’s early PC system requirements on the OC3D Forums.
